- Feb 5, 2007
- 25104
- 162
I started by moving all of the electrical forward. I then took a piece of 3/4 pressure treated for the bottom. Then I cut 4 pieces of 1/2 cabinet grade plywood for the dividers. Each divider had to be scribed on the back to match the contour of the side of the boat. The dividers were plumbed up in place so they would look straight. The top piece was then installed. The two end pieces were installed out of plumb to match the walls they they touch on both ends.I then removed it and built the face frame and shelves. I put an opening under the middle bottom door for storage under neath. I installed a new piece of pressure treated in the cabin below on the edge of the floor to create the storage area. The Teak on the back of the cabinet is actually glued to the fiberglass on the boat.
