440 Express wiring question
Moderator
I went to change my CO detector and shorted out the wires, so I no longer get power to them. I don't see a breaker for them, anyone know if there is an in-line fuse somewhere?
Bob J
Can you not trace wires from CO detector to feed?
Or run temp wires to unit to see if it works.
BOB J
Bob J
BOB J
Moderator
BOB J
The wires are inside the wall. Checked wires with volt meter, no juice.
WALSHIE
Well-known member
FWIW - my boat has a blade fuse near the electric panel, no breaker and is hard-wired to the batteries. I'd start testing all of the fuses you can find. Hopefully it is not in-line and hard to find (like my blowers are, duh!!)
