- Jan 1, 2000
- 847
- 249
I’ve used MikeeH’s potion for years with these conditions. Boat is stored in upstate NY (COLD) in a large lean-two type building out of the elements but exposed to the local temps. Boat is stored with cockpit cover on, followed by a blue tarp to keep the bird crap off. I open all windows and hatches that are under the blue tarp.
Everything comes off the boat except inside cushions and mattress. They have a PFD between the cushion and what they rest to allow air to circulate. All doors are open.
I use several damp rid hanging things you can find anywhere, as well as seven small plastic cheap (Chinese lead filled) containers with kitty litter and damp rid or rock salt. I also use about a box of moth balls distributed throughout the boat in cups with holes in them and have them loose anywhere were I think a varmint may invade the boat – although unlikely. Every thing is cleaned prior to close up.
They key is to eliminate the chance of animals and place something in to soak up the moisture. Previous to MikeeH’s potion I also used charcoal to absorb moisture.
I know this is overkill and with the windows open almost defeats the purpose of the dam rid, but it works for me.
