Be careful the cheap stuff is not meant for motors.
For a few dollars more better to use the good stuff that also has corrosion inhibitors.
Good stuff uses Propylene Glycol and cheap uses a alcohol blend.
Ace stuff is not safe for motors.
I think it is pg but has no rust inhibitors
I just stopped in walmart to get my oil.
They have the prestone -50 PG for $4.
Same ingredient as worst marine.
It's alcohol free and has rust inhibitors and says it's safe for motors.
