Anyone ever use kroil ?
iboat2
New member
I stumbled on this product online somewhwere,
it's for unfreezing shafts, bolts, etc. I have
a frozen tilt assembly shaft. I was able to replace the tilt motor without removing the
entire tilt assembly and have the tilt working but eventually the entire assembly will need to be removed and the shafts at both ends of this tilt assembly are frozen into the bracket. I've not used air hammers or anything YET but with just a brass punch i had no luck, there is
probably a special puller which I may need to
use. I was however curious about this "kroil"
and wondered if anyone has used this with some
results,thanks in advance for any comments or suggestions.
