Hello,
I noticed that water was collecting in the center dry well area (where the air cond. and shower water collects and is bilged out). When the bilge pump cuts on (it has a seperate float switch) it runs for about 2-3 seconds and cuts off. There is still about 2-3 inches of water in the reservoir. The switch seems to engage when the water is almost need the top of the switch. I poured water in and got the same results each time. I have noticed that the cabin floor has been soaked after running. It seems like the water is spilling out while under way soaking the carpet in the cabin. I have cleaned the float and if I manual run the pump from the float, its removes most of the water. Could this be a float issue where the switch cuts off too soon? It seems to be the opposite of sticking.
Please give advice.
P.S. The bilge area around the motor has a minimal amount of water and the plug is new and not leaking.
Please give advice.
