I usually put the pink stuff in the fresh water tanks, and then open all faucets till I see the pink stuff coming out. I also flush the toilet (electric head) till I see the pink stuff in the bowl.
I really hate the fact that when I commission the boat in the spring, it takes like three or for tanks (100 gallons) of water before the smell goes away.
I have played with blowing out the lines a few times but chickened out and added the pink stuff after.
When blowing out the lines, I hook a compressor to the dockside water, opened up all faucets and blow the water out, all looked good, stopped the blowing when all water was cleared from the lines.
Here's my concern and my questions.
The head, do I keep flushing the head till I get just air coming through?
How does the pump that pumps the water get winterized? I assume that by blowing from the dockside water inlet that does not go through the pump.
If the tank (two tanks) has less than 1/8 of water in it and it freezes, will there be enough room for expansion?
Since I have two tanks that work in conjunction with each other (one filler and a hose that goes from one tank to the other) the hose that connects the two tanks will always be filled with water, will this hose crack when the water freezes?
Any advice in this matter is appreciated, thanks.
