I apologize in advance but this will be a long story. At the end of last year a few things happened - my age old mechanic closed his shop before winterizing time and I knew I was on my way to needing a carburetor rebuild. My boat is old but very dear to me and somewhat fanaticaly maintained and touched by very few hands. It is a 1991 Chaparral 2000SL with a VP DP 570 and it scoots. I looked around for a somewhat reputable place to winterize - thinking to some degree - how hard can this be? I had it done. Fast forward to about a five weeks ago. I went to start the preseason prep routine with my son - the oil change. We found a screw driver in the bilge - not one of mine. Figured the winterizing crew got careless but did not think much more of it. The next week we put the boat in the water - fought with it with a stubborn (not working) choke to get it started. It sounded really weird and different than ever. I got it out of the 'no-wake' zone and hammered it thinking I needed to get the cobwebs out of it. It would not even plane. I went less than 100 yards and decided it was time for the carb rebuild but I could not get over this sound. I opened the hatch and looked inside the engine compartment. The winterizing gurus not only left a screwdriver in the bilge, they left a hose disconnected that was supposed to connect to the exhaust manifold on the port side. The stainless steel clamp was nowhere to be found so I bought one and reinstalled the hose. I removed the carburetor and had it rebuilt (by known experts (Carburetor Specialists in Alpharetta, GA - Awesome guys!!!). I reinstalled it. I put in the water today. Started right up. Could tell it wanted to run. Started running hot while at the dock. I pulled it back out. I checked the impeller. It is perfect (just replaced it last year). Obviously no water is getting to the impeller or air is getting sucked in from somewhere and there is a weird sound. Engine is definitely running dry. How do I get it primed. This has NEVER happened before!! I can only figure it HAS to be something resulting from the winterization. I absolutely do not want those guys touching my boat again. I appreciate the help in advance and again - sorry for the long post.
