I have a 325, and the dinette table is triangle shaped. Some of the 325/326's have a dinette table with two of the corners cut off at an angle, making access to the dinette much easier. I want to either buy one with the cut corners, or perhaps modify mine. Does anyone have the dimensions of the cut version. Or, does anyone have a source or suggestion where I could get one made that is like the newer boats with the molded tables that look like solid surface, but is light weight, not the stone products we use at home.
