Carver 356 question???
jgrothe
On a 2001 Carver 356 there are 4 switches at the end of the galley just opposite the booth. The bottom two switches don't seem to do anything, except one of them turns on a little green light just below that switch. Can anyone with 356 knowledge tell me what they do...or should do? And, what does the little green light indicate?
Thanks.
The little light is probably an indicator that something is on. ER lights?
Ok, I have the exact same boat. The one with the green light is the engine room light. If it is burned out, the light is directly under the companionway steps at the rear of the ER. You really have to stick your head in the bilge and look up to see it.
The other switch is the one puck light directly over the dinette.
I'm in the process of replacing the halogen bulbs in all the pucks with LED's. Amazon has a 10 pack for $12.
The halogens have a temp around 200 degrees. The LED's are under 120. Big difference.
If you haven't already, you need to join the Carver owners website forum
