I wasn't paying attention and left the cap off of the starboard gas tank last weekend. A storm came through and the run off from the bow (the only part sticking out from under the covered dock) went down the side decks and a bit funneled down into the gas tank. I would guess it was less than a 1 gallon, but am not positive, as I had forgotten that the cap was off until my daughter screamed that there was water flowing in to the tank a minute or two after the rain started.
The tank has about 65 gallons of gas in it.
I was thinking of pumping the gas from the starboard tank, through a water separator, and into the port tank, then pumping it back to the starboard tank.
I am due to change the fuel filler hose that goes from the deck to the gas tank. So, I figure that I can use the tank filler hole to visually inspect the tank after pumping it out to be sure it is empty.
Thoughts on how to deal with this?
