Originally posted by Robyns Nest
I still stand by my words.
One of the best, if not THE best marine engines CAT ever made.
Jonathan
My boat has 375hp 3208's and the engine surveyor made this same statement almost word for word.
When I bought the boat, my engines had been mistreated. The PO had replaced the dry risers with a "standard" riser, hose and fiberglass elbows. This had cooling water injected into the exhaust BELOW the water lift muffler. The turbos were bad (boost below spec) and the back presure was above spec. The surveyor felt that the engines had not yet been seriously been harmed. In fact, he said that "in their current condition, these 3208's were better engines than some of the newer Cat models". There are very few special tools required to work on the 3208. The surveyor stated that anybody mechanically inclined with a standard set of SAE wrenches could maintain and repair these engines.
After purchasing the boat, I was able to make all the repairs myself with a few hours of consulting advise from a mechanic that has 30 years of Cat experience.
After the engines were "healthy" again, the only issue I had was the throttle shaft seal on the injector pump on both engines failed. Both failures caused the engines to quit running. The first one I was close to home, and got home on one engine. The other one failed away from home, and I was able plumb in an electric fuel transfer pump to keep fuel in the engine (the seal is on the suction side). This got me home and leaked very little fuel (transfer pump only ran at 5 psi).
I still wish I had a little bit more power. I cruise around 18 kts fully loaded with fuel, water, and supplies for a week in the Bahamas. When fully loaded, the boat will occationally fall off plane when encountering a head sea. When this happens, I'll bump up my cruise RPM's to 2550 to stay on plane.
To recap, 3208's are great engines.
