Check Valve Question
compdr59
I have a manual head and I would like to hook it up to potable water instead of the salt water. I only have one holding tank. What type of check valve can I place on the water inlet side so I won't have any fear of backflow that could cause contaminiation. I would place it on the non pressurized side of the system. I can't find any exact brand or model for this. Any information would be helpful. Thanks and happy holidays.
There are check valves & then there are check valves. I, personally, would not feel comfortable knowing there was even the slightest chance of waste water entering my fresh water supply.
in addition to the check valve you should install a vacuum breaker in the line,after the fill valve. This will eliminate any chance of back syphoning.
Who makes these check valves and vacuum breakers and where can I get them.
look ino your home toilet and see that every sewer system has an air gap to make flow back impossible.
Manual toilets are designed for raw water use only. There is NO SAFE WAY to connect a manual toilet to a potable water supply. Don't even think about doing it. If you want to flush with fresh water, add a dedicated tank that feeds only the toilet, and refill it as necessary.
Or, add a "Y" valve to the vanity sink drain in the head, with one output of the "Y" valve re-connected to the existing drain and the other output plumbed to the intake of the head. When you want to flush the head, turn the "Y" valve to feed the head, and run some water into the vanity sink. Then pump the manual head. When done, return the "Y" valve to the previous setting.
Also, with the "Y" valve method, you can leave the water in the sink after washing your hands, etc., then use that water later on to flush the toilet. So you can get additional use from the water before it goes overboard.
