Also no direct experience but if that was made in Taiwan boats of that era were noted for wood window frames and other trim that was difficult to maintain. Water leaks were common with accompanying consequential damage. Careful inspection is a good idea. Also do careful inspection of areas under teak decks.
never heard of them till today either... seemed to be priced on the higher side of comparable trawlers of that vintage. Like most of these far east boat, watch for bad fuel tanks which can be costly to replace...
I recall problems with the rudder bushings and shaft seal on one a surveyed years ago. Also there was an area in the aft cabin on the starboard side that had damage to the wood on the inside of the vessel towards the sole area.
