Over the winter I had the motor rebuilt for my ski boat. Sbc, mostly indmar, pretty simple.carb motor with Mallory electronic ignition, no spark, and I seem to be having a problem getting 12 volts to the coil, and surprisingly the problem is with the negative side - it's losing two volts somewhere.
There are two wires on the negative terminal - gray which goes into the harness, for the tach I assume.
And green which comes from distributor. The distributor shaft appears well grounded, and shows 12 volts when I put the - lead from the volt meter on it. But the wire to the coil from the distributor doesn't carry the full voltage.
Any idea what could be going on here, and best way to fix? Was considering running a wire from coil neg to a good ground, but maybe I have an issue that needs to be addressed?
