compound or fine grit sanding?
mikeskeetr
So, I have this red boat that has quite the heavy oxidation on it.
I bought some 3M super duty and went to town on a small section... Turns out that under the red is a nice, dark rich, 'blood red' that I am guessing may have been the original color (its STUNNINGLY beautiful), and the compound is bringing it out.
So, my 2 questions are:
1) Any opinions as to if this is just oxidation or maybe a newer paint job went over it?
2) Is it possible to remove heavy oxidations with maybe a 320 grit (wet or dry) sanding, then wet sand to 1000, compound, finess-it, and wax? Or would that just kill the gelcoat altogether?
Mind you, the blotchiness came from compounding EXCESSIVELY (4x) to this point in a small 1'x1 1/2' on the transom just above the rub rail (more oxidation above than below rub rail). It is super smooth - so its not like the compound didn't do its job - and when waxed both reds shine nicely - I just like the deeper red much better. In the end I am wondering if there is a safe way to bring it out without having to paint it or without damaging the gelcoat.
I know someone posted a similar query recently, so I apologize in advance if I sound a little like a broken record...but the fact that it took a lot of compounding for this to show up makes me wonder if it can be saved at all...
Thanks!
- Mike
IMHO, the less aggressive the better. If compounding will do it, compound. I have used Aurora with great results on my Regal. Lighter oxidation than you describe though. Red boats are like black cars. They look great when they're clean but a b!tch to keep that way.
Good luck.
Post some before and after shots.
Use the finest compound you can use to make it blood red. Once you're there use a very fine compound to bring up the shine and then wax with a good product to protect the shine. If compound won't do the trick, then you are going to have to wet sand it with a fine grit paper. Again start with the finest paper and then go to compound and wax to finish.
If you wet sand you'll need to go up to 2000 grit working up in stages. Otherwise you'll have a bunch of shiny scratches.
