It is pretty simple. I did the same with my two grey water tanks. I drilled a hole in the top of the poly tank and installed a uni-seal, piece of 1/2" (I think) PVC pipe with the end that goes into the tank cut on an angle. On the other end I attached one of those QD 90 degree fittings. Ran tygon tubing for the QD to a pump (3.5 gpm), and from there overboard. I throw a switch when I want to pump it overboard. I can give you more details later, as I am at work and don't recall all the sizes, etc.
