Displacement is the weight of the water that the boat displaces when it is floating in the water.
If a boat has a 25 ton displacement, then that is the weight of the water that was where the boat hull now is, up the the waterline.
Dry weight is the weight of the boat like new, no water, oil, fuel or supplies on board.
Displacement is theoretically the same as the actual boat weight. The more weight you add to the boat, the lower it sinks in the water,
the more water it displaces, the higher the displacement weight.
The boat will be lighter if weighed when in water than on land due to the force of the water pushing on the bottom. Bouyancy.
The displacement weight will change if freshwater and saltwater. It will also change in hotter water or colder water due to
density of the water.
A boat will float lower in hot salt water than cold salt water due to the density of the water changes with temperature.
Same with freshwater temperatures.
