I have a 1979 Galaxy Bow Rider that I am replacing the floorboard where it is rotted. I have a ton of foam inside the hull, but obviously it is wet as the lake.
Should the bottom hull be water tight or mostly water tight with drainage to the bilge pump?
Mine does not drain as there are no holes between the hull and the engine area where my bilge pump is.
Please enlighten me.
