Vic,
I have a three year old electro scan that seems to have a non-functioning macerator pump. I have a couple of questions:
1) I have a macerator on the toilet (raritan Sea Era) is that sufficient to keep the system functioning correctly or should I go ahead and get the replacement kit from raritan?
2) The system was functioning well until I moved the boat from salt to fresh water. It may have been coincidence but now doesn't seem to be running (the noise from the flush cycle is much reduced). Is there some way to make certain that the mascerator is not functioning?
3)I've been using "solar salt" (1/4 cup per flush) and the current is fine (approx 17amps) but the salt is large crystals and there is significant grinding noise from the raritan Sea Era toilet. A simple test shows that the salt is NOT dissolving completely so is it ok to continue using the salt or should I switch to fine granulated table salt?
Thanks for any help you might be able to supply.
RB Cooper
RB Cooper
