Hello all - I haven't logged onto BoaterEd in a long while, however this afternoon I found an issue with my boat and, well...this is the first place I thought of for help.
A few weeks ago I pulled and winterized my 4.3l Mercruiser. I ran antifreeze through the muffs and used at least 4 gallons to ensure that antifreeze was in and water was out. After some recent freezing temps nights I went out to cover her before the snow starts falling. I reached in to check the engine and squeezed one of the water intake pipes and it is frozen. I can't squeeze it. I disconnected the pipe and it smells like antifreeze but seriously, the pipe is frozen at the lower elbow. The end I removed is 'crystalized' as I would expect.
Now I'm worried. Did I winterize correctly? I've done this method for years without issue and to be honest I wouldn't normally check on it after winterizing.
Any advice? Anything I can do? Should I worry?
Thanks!
Bcat
Thanks!
Bcat
