mandm1200, I think in the instance you noted, that you would absolutely be entitled to get your money back for the survey.
But, that's not what you are after now is it?
Walter, I think its a big leap to expect that a professional surveyor is qualified for every boat they look at. Especially with boats, I bet it is very common practice for a highly experienced, well qualified surveyor to find himself looking at a boat he has never seen before. Is he qualified to make engineering (stringer) evaluations, not being an engineer and also not having the experience of having seen that particular boat before? I'm just saying that if you get into a court case, the reality is that its probably very easy to demonstrate that even "qualified" opinions are frequently wrong in this industry. By extension then, most surveys have errors (every single one of the ones I've look at have, at least minor ones), that is common place and that unless there was gross negligence, that the purchaser of the survey likely received usual and customary value. To say that the surveyor is going to be liable for replacement of fuel tanks or similar, I just don't think its reasonable to belive that any of us are going to be able to achieve that in any typical situation.
That said, I personally still believe in the value of good surveyors.
Lest any of you think I don't have skin in the game. Some might recall my first real boat, the 23 Penn Yan. I had an engine guy come out and go over the engine. He wrote up findings and gave the "all's well". He had noted moisture in the rear cylinders, but did not think it was a big problem. Knowing what I know know, that was a huge red flag that the risers were rotten. I didn't know enough then to get somebody worth having. Credentials frankly are meaningless. Sure enough, first real day out on the boat after purchasing, day 2, the engine craps out. We pull the heads and all is revealed, 8K later I have a boat running with a fresh rebuild. The boat only cost me 7,500. Do you really think I could have sued the mechanic and got anything but his fee back. Lets say its his fee *3, it still is not worth the time to pursue.
So, yeah, the "day after I buy it" stories are not just examples. They happen. I've got plenty of skin in the game. All that and I still say you are barking up the wrong tree.
Just my opinion though. You don't need my agreement. If somebody can win one of these suits AND not put an end to the surveying industry as we know it, more power to you. If surveyors do end up being liable for these kinds of things, few of us will be able to afford one.
Do the math and the whole idea is a non starter. You have to take responsiblity for your decisions, even if you do farm out the work. That's why you get references and at least know enough to determine whether you got your money's worth from the survey. If you don't think you can do that, then hire surveyor to survey the surveyor. It's your money. Be wise.
