If you drain the raw water side properly a/f is not required. If you are a belt and suspenders kind of guy and you want to have a/f on the raw side add head to the process.
I would hook up a transparent hose to the plunger, cut to proper length, get a funnel, take the hose, funnel, a/f and yourself up to the cockpit and pour a/f into the funnel until your system is full. Gravity should do the work.
If your entire system is raw water cooled you may be better off to add a/f directly to the engine from above. Do this after very completely draining the entire cooling system to include manifolds, the block, water pump, etc.
