I have twin 2001 Crusaders 5.7L 'captains choice' motors. The port side decided it does not want to run! I verified spark and it does run with ether. Fuses and relays are good. There are two fuel pumps, a low pressure and high pressure. Both pumps show voltage for a few seconds when the key is turned then shut down. This is apparenltly as designed since the starboard engine does the same thing! It's not the fuel filter (we switched them).
So,,,,how does this two fuel pump system work? Is there a sensor that engages the fuel as per pressure? If so, this could be bad. Why does the electric go on then off?
Another thought is perhaps a low oil sensor is faulty and the computer is shutting down the engine?
Any thoughts are appreciated.
