I didn't want to hijack the other thread regarding generators but as mentioned, Kohlers can be a PITA. I have a 7.3 Kohler, I assume around 2001. I admit to being the person that does not use it! There's no easy way to run the carb dry so I don't do that when winterizing either.
I want to get it working! I change the impeller, removed and cleaned the heat exchanger (was fine), oil change, etc. It starts with the help of staring fluid, can power the boat. But it shuts down after say 10 minutes. I wish I knew why! How can I check for overheating? The exchanger is cool when it shuts down, I guess I should check the thermostat next but I wish I knew it shut down from overheating.
I'm hoping I can run it frequent enough to self-clean the carb with clean fuel...is this a pipe dream?
I've read where people say "change the spark plugs" but really?? Do you guys believe that?
