Delta dawn
- Oct 9, 2004
- 15495
- 44
I'm thinking of installing a Golden Rod in the engine compartment of my twin gas inboard engines and found this information from the manufacture:
"How does GoldenRodВ® work?
GoldenRodВ® heats to a surface temperature of less than 150 degrees (which is almost too warm to hold) and circulates warm, dry air throughout an enclosure on a 24 hour basis. This increases the temperature of the air inside to several degrees above the ambient outside temperature. Expansion of the heated air forces the moist air outside through the vents or loose fitting doors leaving the dry air inside. In order to work correctly, it is important to ensure that there is adequate ventilation.
Can I install GoldenRodВ® myself and how do I install it?
Yes, you can do it with simple tools. Using a drill and screwdriver, just attach the universal brackets using the enclosed screws. Then snap the GoldenRodВ® in place into the brackets. The GoldenRodВ® MUST be mounted horizontally at the bottom of an enclosure to work effectively. "
I'm a little worried that heating the comparement to drive out moisture won't help with keeping the compartment from freezing, and needing ventilation will only ad to the cold air coming in. What do you think? Many thanks!
