I have two questions, one may be obsolete after I replace the two heads in an 88 372 Chris Craft. Both heads are electric discharge. My experience with marine heads is very limited. I had a 31 ft Chaparrel that I could see what I think is a vent loop. On the Chris Craft I just purchased I don't see the vent loop. This boat has not been used very much in the last two years, but looks as tho it might have been winterized.
First question...the forward head when flushed shoots water out of the head, I assume a bad impeller. The aft head flushed out fine. When I poured water in the forward head it flushed out but when the bowl was dry it shot water out again. Poured more water in, and it flushed out fine. Went to the aft head and it was filled with water, I assume from the forward head when it was flushed. Now the aft head will not flush. I bailed the water from the aft head, pressed the button and it filled with water but would not flush out. The holding tank is dry. There are one hose from each head going to the holding tank. The discharge seacock was open so I closed it off. The aft head will not flush out with the seacock open or closed.
Any idea what's going on? The reason I want to know is because I'm not sure if I will have the same problem when I replace both heads.
Now the 2nd question. Suggestions as to which head I should replace these with. Like I said before I have limited experience with marine heads. When I replace these I assume I should replace both the pump and head, is this correct.
Thanks for all the suggestions.
