We're planning on taking the sailboat from Rio Vista down to Antioch in a couple months. Our two possible routes are:
1) Down the Sacramento River to Pt Sacramento and turn south, through broad slough to Antioch. 14NM.
2) Down the Sacramento River to 3Mi Slough, go under the bridge and around to the San Joaquin at Red 28. Then straight on to Antioch. 14NM.
3) Same as #1, but come down the Sacramento River and cut across Sherman Lake, slip through Mayberry Cut, and pop out at Antioch. 11NM.
It'll be a sailboat - an Islander 26, with 4 feet or so of draft. #1 would be a piece of cake, #2 is a little more involved with 3 mile slough, and #3 is the shortest, and depending on conditions could potentially save as much as an hour. But Mayberry Cut is narrow, and Sherman Lake is shallow.
For one thing, do you think it's advisable to even consider cutting through Sherman Lake on anything other than about a +3 high tide? Depending on which tide we come down on, we could be hitting Sherman Lake on a 1.5 low tide, or a -1 low tide! The more I think about this option, the less I want to do it.
