Hold-N-Treat help w/fresh water Elegance
Vic will the hold-n-treat pull and lift the contents of my holding tank the hose will be about 6 feet long and need to lift the output of my holding tank 2.5 feet to the PuraSan from there its is about 5 feet downhill to the through hull.. My marina is lost and I haven't been able to go down to help them with th installation. I thought the external pump I bought would do that? Tell me if I am wrong otherwise if you could call me at 609-377-0022 I would appreciate it. Bill Lentz
The pump will certainly pump upward 2.5 feet with no problem - will it be drawing from the bottom of the tank or the top, via a dip tube?
Due to hieght restrictions the bottom of the tank Vic. Because I wanted the largest holding tank that would fit (45 gallons). There are no top hoses even the vent hoses are on the upper corners. There just wasn't any room left when the new tank was shoehorned in. All plumbing faces aft out of the rear of the tank. The blackwater feed is at the top edge and the exit is on the bottom edge. 2 vent hosos are on the left and right upper corners of the side of the tank. Picture a rectangle the smaller rectangle is the 2 ends of the tank. The long portion of the tank runs fore and aft. I hope I painted the proper picture.
Shouldn't be any problem whatsoever. Best of luck with the installation, and have a great weekend.
