I just removed my blown out water heater. Needless to say I had to cut in half to fit it through the companion way from the engine room. I now have in mind a smaller heater that is fewer gallons. It is rated for 110 volt or 220. The plumbing guy said it should be hooked as 220 to get proper capacity. The one removed was 110 volt. Can I just run 220 using the preexisting line (it would be very difficult to re-run wiring)? Is this just a Matter of changing the breaker in the panel? Is this a no brainier? My electric knowledge would fit a shot glass!
Tired of cold showers!
