I have had an ongoing problem with one of my Crusader 350's. After the motor runs for 15 to 20 minutes it losses power and even misses under load. I just reworked the heads with all new gaskets and she sounds great. Around 150psi cylinder compression. The mechanical fuel system, distributer, wires, plugs, cap, rotor, are all working good. The ingnition switch and wiring is original and 25 years old. Is there anything in the system that could get hot and make the engine loose power?
-Mike-
-Mike-
