My 1997 330 Sundancer has I think the 5/8" water lines with all quick disconnects.
Several of the quick disconnects are leaking in the area of the hot water heater. I push the line fully into the quick disconnect and it's OK for a while, then the pressure pushes it back out again.
Question is should I replace these, or try another type of connector such as those used in an RV?
Thanks.
Thanks.
