I have a 1987 Searay (sea ray)39' Express Cruiser with water leaking in to the rear port side cabin. It's leaking into the the area where the air conditioning controls are located.... inside the cabinet. I believe it's coming in the cabin through the side windows. (maybe the windshield deck area but unlikely)...
Is there some way or method to determine where the leak is coming from????.... and if it is the side windows how do you reseal the window????
ALL ...suggestions, experiences and solutions are appreciated.... I'm sure I'm not the first with this problem.
Thanx in advance for your replys.
JD in RI
JD in RI
