Looking for a replacement coffee machine
subsonic
New member
Hi Guys
Our black and decker odc-150 spacemaker coffee machine has died.
What have you guys found as replacements that work well in the same slot?
Thank you
Stuart
I removed mine you gain a lot of space and I bought a Keurig much easier and it gets used all the time.
subsonic
New member
Thanks Dave. I thought about the Keurig idea but the opening is only 10.5 inch high so not really big enough to use for a Keurig without having to keep moving it in and out. How did you get around that?
I keep my toaster oven where the coffee maker was and the Keurig stays in the center bay near the window it stays plugged in but I pull it out onto the counter when I use it.
