- Mar 1, 2000
- 6
- 231
ON / OFF MASTER DISCONNECT - ONE BATTERY - #A
Installation to shut off all power at source.
BATTERY SELECTOR SWITCH AND MASTER DISCONNECT - TWO BATTERIES - #B
Installation to select a starter battery and ship service battery Manually isolates each battery, parallels both batteries for "power" start, master disconnect, manually selects batteries for charging.
ONE ISOLATOR - ONE ALTERNATOR - TWO BATTERIES - #C
Installation of isolator automatically selects lower charged battery to be charged first. Full battery can not discharge to drained battery. Dedicated system, no flexibility, no "power" start parallel or master disconnect function.
BATTERY SELECTOR SWITCH AND MASTER DISCONNECT WITH AUTOMATIC BATTERY ISOLATOR AND AUTOMATIC CHARGING - TWO BATTERIES - #D
Installation of an isolator automatically isolates each battery, lower charged battery will automatically be charged first. Two different size batteries can be used, larger for ship services, smaller for engine starting. Switch selects usage, master disconnect, "power" parallel function.
ONE BATTERY SELECTOR SWITCH, ONE ON / OFF SELECTOR SWITICH. AUTOMATIC BATTERY ISOLATION AND AUTOMATICALLY CHARGES 3 BATTERIES - #E
Installation for use on powerboats, sailboats and trawlers, used for temporary living. Third battery isolated from other ship circuits. All batteries being automatically charged while running through isolator. To be used for refrigeration or other heavy load devices. Isolator protects other batteries. Switch selector usage: 1. Master Disconnect 2. "Power" Parallel function.
ONE BATTERY SELECTOR SWITCH, ONE ON / OFF SELECTOR SWITCH, ONE ISOLATOR - TWO ALTERNATORS - THREE BATTERIES - #F
Installation of isolator separates both alternators so both alternators will charge simultaneously, automatically charges lower charged battery first. All batteries can be used for start, third battery, ship's source.
ADDING AUTOMATIC BATTERY CHARGER / CONVERTERS TO SYSTEM - #G
Installation of dockside multi-bank charger with built in isolator which will automatically charge lower battery first.
