My trim pump seems to have died. The relays click in trim in/out and trailer but no motor sound.
I assume I need to replace the motor? What is the easiest way to pull only the motor off? There are 4 bolts on the top of the motor will that allow the motor to be removed.
I also checked for +12 on the solenoid output and with a jumper wire gave the solenoid output +12.
Best place to get a trim pump motor?
