This weeks project is installing overhead lighting on my Bimini. My boat has zero overhead lighting, so i had a 1/4" x 1" x 70" piece of starboard cut, to which I affixed a waterproof RGBW led strip with double stick reinforced with 1/2" plastic Romex staples. Looks real good, and I secured it to the Bimini with snaps (to the underside of where a tube runs - hard to explain). Anyway, I want to keep the controller inside the dash, so I need 5 conductor cable that I can run up one of the support tubes. It will need to be as thin as possible, I'm thinking 20ga/5 and will definitely need to be UV resistant, as it will be exposed all day, every day. The supplier provided some Belden cable, but it's PVC jacketed, which I suspect won't hold up long (no uv resistance mentioned on Belden's site). Ancor makes a 14/5 cable, but that's going to be way too thick to run up a 1" ss tube with zip ties... Any suggestions?
