Surprisingly easy. At least for my model, which is old, but I think the process is the same.
You remove the clamp around the bowl. The bowl then lifts straight up off the base. Under it, without obstruction is the bowl seal. Two flat seals go there. Pull the old one off, sit the new one down, then sit the bowl back on and reinstall the clamp. On mine, I had enough hose length to lift the bowl without removing the hoses.
The last one took me 15 minutes start to finish and it was the 2nd one I had ever done.
