Prospective
New member
- Sep 7, 2006
- 23085
- 1,343
New boat so I've been running thru in my head winterizing proceedures. Assuming I want to change the oil before layup, should I do it on the hard or in the slip?
Reason I ask is I'm also assuming engines should be warmed up prior to change. That was no problem on the gas boat which could be run on muffs on the hard. But not sure new boat can be run on hard off of a hose. Kind of doubt it. That would mean doing oil change before getting hauled. Then winterizing engines with pink after haul.
The hassle is the slip is not where I will be storing and I pay the mechanic to come to the boat. Trying to avoid two trips.
