This ol' 1958 Starflite V-4 50 hp seems to have a fuel supply problem. It will run on the hose in my driveway for about 6 - 10 minutes and then shut down, refusing to restart. I checked the plugs, and they are dry. The manual on the motor says the fuel line connectors at both the 6-gallon portable tank end and on the motor end require an O ring, and will not draw properly without it. I've looked at both ends carefully----no O ring, and I can't see where to put one. Can you clear this up for me?
Craig
Craig
