I have 2003 34ft Kevlacat powered by 2 225 4 stoke Yamaha OB`S, the Outboards sit on fully enclosed ali pods which sit 4inches obove the bottom of the hull line ( the motor cavitation plate sits level with the bottom of the hull line)I am not happy with the boats performance there is alot of foamy water arrond the lower leg area it dosent make any diff if i trim out or inspeed is the same , i am contemplating extending the pods to match up to the hull shapeto give clean water to the prop area, what are your thoughts ,the latest model has a redsigned pod fitted kevlacat lower and closer to the leg
Maurie
Maurie
