Pink Antifreeze
ALKA2710
Have a weird question. Poured 5 gallons of pink into my 5.0 motors thru the 3 heating hoses on the motor. Before I did this i drained the block. Came back a week later and i had a gallon of antifreeze left so i figured I would top off the hoses so i disconnected them and as i topped them off clear water came out of one of the hoses as the antifreeze filled up. Now mind you when i first put the antifreeze in it flowed out of the other hoses pink. Now a week later it came out clear. Does water rise to the top of antifreeze or change color as it sits in a motor. This one has me stumped. Thanks
Al
Normal antifreeze will mix with water pretty well, not separate.
I am not sure about that pink stuff.
