Pressure washing
Oldshore
Could any damage result to fiberglass with pressure washing? I understand pressure washers can be all different pressures and have used on on my wooden deck. They can tear up wood pretty well if not used properly. On an old fiberglass boat I am concerned high pressure could get into cracks in the gel coat wreaking havoc. Anyone have personal experiences with it causing damage?
Jay
I have seen gel-coat come off with as little as 1800psi! Jay
Looks like I will be on my hands and knees with a scrub brush and garden hose.
I use a 3K PSI washer to clean my non-skid when it gets too funky for routine cleaning. It has not been a problem on my small Whaler. I do use the least agressive of the nozzles to minimize any chance of damage. The nozzles with the widest spray angles are the least agressive.
When the deck is very bad I use some deck cleaner before washing. I just spread the cleaner around with a soft brush then hit it with the washer. It takes very little time and effort.
Wash the boat several times a year with3100PSI Pressure Washer. Only Gel Coat it's taken off was stuff that would have come off with a stiff brush.
I've always been hesitant to use a pressure washer for fear of forcing water under and around fittings that have been bedded such as cleats etc.
