Pump out problems
BillyK
Hi ,
I have a stinky problem. I'm having issues getting my holding tank pumped out. I found my vent was clogged and replaced or cleaned all the parts and it vents like new. I checked the suction hose which is three years old and it is not clogged. I can't get the 90 off the tank, but it appears the tube is still attached. I don't know what could be the problem. Has anyone had trouble pumping out and found sludge at the bottom to be the cause. If so what was the solution?
Billy K.
Moderator
You said “can’t get the 90 off the tank but it appears the tube is still attached”.
I assume this means you have a dip tube at the top and not a fitting a the bottom. If so, and if you are sure there are no vacuum leaks in the hose and pump out out fitting connections, the problem has to be the tube.
When you connect the pump out, try listing for any vac leak at the fitting or at the top of the tank
BillyK
Will do. I have the truck coming back Wednesday, so I can be there. Thanks
BillyK
There is a product called NOFLEX DIGESTER that I use and it truly breaks up the sludge and oxygenates the tank.
I bought a product at my go to plumbing supply. It's called Bio-Clean. I'm told it will do the same thing. Thanks
BillyK
Pump out today was successful. I'll never be sure what was the secondary problem, but the vent was clogged for sure. No question the Bio-Clean helped the sludgy bottom and I will continue to use it.
Thanks for your solutions,
Billy K.
  • Like
Reactions: Cam
Billy
I think your in Patchogue, does your pump out guy go to Center Moriches and can you send me his info?
Thx
Andy
BillyK
Hi Andy,
How are you doing?
We use Outback Cesspool services. They are probably closer to you then me. Their number is 631 289-6200. What Marina are you in now?
Murry,
As described above, the problem is resolved. I recommend the Bio-Clean to keep everything as smooth as possible.
Billy K.
Hey Billy
Doing good
Not a Marina, hopefully closing on new house within a week or 2 in CM, 80' bulkhead- deep enough for my ride BUT
will sell the boat and get something(s) with less draft for the bays. I think my big boat days maybe over
Hope all is well with you
BillyK
It is a lot different then Greenport. Good luck. Glad everything is going well.
