This is my first post to this site!
I own a 1994 Carver Voyager 320 (350 Crusader power). I've had the boat since 2008. My water heater leaks and needs replacing. It is an 11 gallon Attwood which I'm replacing with a 6 gal Kuuma (big enough for my use). The problem I'm having is how to remove it from it's location inside the galley cabinet (it is located between the sink and port side of the hull. I've managed to remove all 8 screws holding it down, the rear exchange hoses from the port engine have to be remove as well as the shore wiring but the big problem is the route out. I have investigated weather the cabinet may be disassembled but think everything is glued. My present thought is to remove the 3 draw slides (easy), the refridgerator (already done) and to cut an opening (about 20" X 20") in the internal panel to the left of the fridge. That panel does not appear to be moveable. Does anyone know a simpler method before I start this? (Someone please say YES!).
Thanks for any inputs.
CAPT'n Popi
CAPT'n Popi
