If this is a raw water cooled engine, that's not really the best way to do it because if the thermostat does not open all the way, you can get full strength antifreeze in the manifolds and a weak antifreeze + water mix in the block, which could freeze. I tried this once, check the block drains, what drained out was mostly water, with a bit of AF in it...
If you want to leave it in, which does help with reducing corrosion, the best way is to flush the engine, fog it, drain everything manually, poke the holes to make sure, and then replace the drain plugs and back fill the engines and manifolds with -100 with has more than enough freeze protection, even if a bit of water did not drain....I've done it this way for years and never had a problem...
The other way, has resulted in popped core plugs and cracked blocks in the spring. It is possible on a cold fall day that the thermostat would take a long time to open, on a raw water cooled engine with cold water from the hose running through it..
If you don't want to use AF then just drain it, poke the holes....
