I need to replace seals on the water pump on my 1988 Mercruiser 165. To accomplish this I need to first remove the stator. Using a wheel puller I started pulling the stator but it looks like the cast iron case is coming off but not the guts with the windings. Is this correct that the outside case and the inside with the windings come of separately?
TIA
TIA
