I need to replace the Tac Drive Coupling on a 2005 420DA /w Cummins engines. How is the Takeoff drive adapter hub removed from the engine? Thanks for any advice.
If so, it looks like the 2 M6 1.00 x 12 Hex screws just need to be removed to pull it out.
Angle adapter #4 is supposed to be oriented 30* from 0* up so I wonder if rotating that part to 0* or other orientation could allow backing it out via a matching slot , or perhaps it is just a tight press-in/pull-out fit in its seal ?
I'm assuming the 420 DA is a Sea Ray model and doesn't really have anything else to do with this part.
