Yes, riding with the tide will definitely save you fuel. How much, I'm not sure anyone can say for sure. It seems that most times I want to go in the direction that the tide isn't. An hour or so before the tide change, I believe would put you in what's called slack tide, where the water pretty much isn't going in any direction. So that would probably be in your favor. You would probably have to check the tide tables for locations on the Hudson to really schedule effectively. Can you out run an incoming or outgoing tide for example? I don't know. Now if you have the wind and tide in your favor, you're really cookin.
