Depending on the tide and location. If you have water moving inland, the water can be anywhere from salt to brackish to mostly fresh. Also, salt and fresh may not readily mix. Some places you can see the incoming and out going moving side by side. Other areas, the salt can be moving in under the out going fresh.
There was a time that the delta was fresh, but since they started diverting water to the southland, salt incursion has been moving further and further into the delta.
Probably more than you wanted to know.
